I have a Pegasus R6 which is not showing up as a connected device in Promise Utility or Disk Utilty. The power light is orange, while all the drive led lights are blue. The R6 does react when I connect the thunderbolt, with the bue thunder icon turning on, but that's it. Can I put the R6 by the trash or is the something I can do to give it a second life???
Unresponsive Pegasus R6 with orange power light
- 674 Views
- Last Post 04 April 2018
Michiel Nelissen
posted this
04 April 2018
Raghuraman Kannan
posted this
04 April 2018
Hi Michiel,
Please follow the below steps and let us know the status .
- Shutdown the pegasus. (If power button does not work, unplug the power cable)
- Change the Thunderbolt slot both in MAC and in Pegasus .
If the unit powers ON with blue light for power then the hardware should be fine. Issue could be with the drives. If power light is still Amber , we might have an faulty chassis.
Let us know so that we can advise on the next step.
Michiel Nelissen
posted this
04 April 2018
Hi there,
This seems to work. The Pegasus is apearing in in the utility software.
What is the best next step?
