Unresponsive Pegasus R6 with orange power light
  • 1.4K Views
  • Last Post 04 April 2018
Michiel Nelissen posted this 04 April 2018
I have a Pegasus R6 which is not showing up as a connected device in Promise Utility or Disk Utilty. The power light is orange, while all the drive led lights are blue. The R6 does react when I connect the thunderbolt, with the bue thunder icon turning on, but that's it. Can I put the R6 by the trash or is the something I can do to give it a second life???
Hi there,
This seems to work. The Pegasus is apearing in in the utility software.
What is the best next step?
Raghuraman Kannan posted this 04 April 2018
Hi Michiel,
Please follow the below steps and let us know the status .
 - Shutdown the pegasus. (If power button does not work, unplug the power cable)
- Change the Thunderbolt slot both in MAC and in Pegasus .
If the unit powers ON with blue light for power then the hardware should be fine. Issue could be with the drives. If power light is still Amber , we might have an faulty chassis.
Let us know so that we can advise on the next step.
