how do I Identify my R6 model from serialnumber?
and where do I find a list with aproved harddrives for my model, want to replace my 2TB drives with 4TB og 6TB
thanks
thanks
Hi Morten,
There are several 3 TB and 4TB drives on the Pegasus 1 compatibility list. There are no 6TB drives, these have not been tested with the Pegasus 1.
thanks
but where dose that put my choise on the compatibility list?
Hi Morten,
Looks like this is the original Pegasus, which we often now call Pegasus 1 for clarity.
The compatibility list and other files are available on the Promise support page in the Legacy section.
thanks
so this is a pegasus ?
Hi Morten,
You can identify which Pegasus you have from the Promise Utility. You can download it from the Promise Pegasus download page. Download the Utility for any of the Pegasus 2 models. It should work for Pegasus 2 and Pegasus 1. Then you can see which Pegasus you have from the GUI or the CLI, In the GUI look at 'Subsystem Information'. Below we see a Pegasus 3 R8.
To use the CLI open a terminal and type 'promiseutil' then Enter. From the cliib prompt the command you want is 'subsys -v'
regardless of R6 model?
thanks
Hi Morten,
When see the compatibility list you will there is Thosiba model (MD04ACAxxx) which denotes 4 Tb Drive. You can replace with Thosiba drive.
thanks, but is that list actual regardless of model?
dont know if my R6 is a Pegasus2?
thanks
Hi Morten,
Please find the below compatibility list for Pegasus2 series
https://promise.com/DownloadFile.aspx?DownloadFileUID=4754
