FTP Setting on G1100
  • 1K Views
  • Last Post 18 July 2017
Boby Irawan posted this 10 July 2017
Hi Supports
I try using ftp on G1100, i opened Vtrak A Class management and i click Nasgateway tab then i start ftp service but after i try connect it using filezila client the virtual ip G1100 cannot access. My question is, how to setup ftp on G1100
Thank you for your advice
Boby
R P posted this 18 July 2017
Hi Boby,
To use the NAS Gateway 'ftp' use the following steps.
1. Enable the 'ftp' service.
2. Enable 'ftp share' and give users access permissions.
3. Login with filezilla or other ftp client.
--Rich
Hariprasad Velmurugan posted this 10 July 2017
Hi Boby,
Could you please confirm the Nas gateway & Aclass 3800fD connected to MAC osx or Linux operating system?
Notes on Current Network Protocol Support for Supported Operating Systems
• Current testing and support for Mac OS X and Microsoft Windows is for the SMB/CIFS network protocols.
• Current testing and support for Linux is with the NFS network protocol.
A. To mount the share with NFS on OS X, it must be mounted via command-line since the 'Connect to Server or ⌘ + K' will fail.   If you want to use NFS, follow the below syntax:   sudo mount -t nfs -o rsize=1048576,wsize=1048576,nolock,locallocks X.XXX.XX.X:/nasmnt/fs1 /private/fs1   Make this auto-mount this with an automaster and autonfs file on OS X.   It is preferable that  SMB and not NFS on OS X.   Our official supported protocol on OS X is SMB.   Regards Hari
