Vtrak E610f converted to an ethernet connection
  • 536 Views
  • Last Post 02 May 2017
Josh Bullock posted this 02 May 2017
Hello.  I have a Vtrak currently on site and I would like to be able to access it via a network connection or a windows box.  Is there any way to do that?
Any type of converter box that would convert fiber channel to network?
Richard Oettinger posted this 02 May 2017
System Preferences -> Sharing
Check FIle Sharing, select the folders to share (the VTrak disk on the Mac, for example)
Set the User and options.
Mount it at: smb://<Mac IP>
So I have it currently connected into a Mac.  How would I go about sharing it over the network so that a Windows 2012 Server can connect to it?
Hi Josh,
The only way to do that is to connect it to a computer and use that to share it out on the network...
~ Richard
