Rebuild doesn't seems to start
  • 832 Views
  • Last Post 11 November 2017
Matti Kautiainen posted this 10 October 2017
One of my 2TB drives went dead from my R6. I replaced the drive with 3TB, knowing it will waste 1TB and choose rebuild.
Now it's been 0% for almost 10 hours in Background activities and no indication of any action at all. Should I still wait or is there some error ?
Unit is configured as raid-6. Can I stop rebuild ?I'd like to make back up copies of most important files if possible and then try again.
Dinesh Kannusamy posted this 10 October 2017
Hi Matti,
Yes, you can stop rebuild and proceed to take a back up of your data and also make sure that you replace a faulty drive with compatible one to check if it rebuilds the array.
Below is the link to download the compatiblity list for Pegasus 1 series:
https://promise.com/DownloadFile.aspx?DownloadFileUID=4127
For any further assistance please create a web support ticket in support.promise.com or contact Promise Tech support: https://promise.com/ContactUS
Thanks..
Matti Kautiainen posted this 11 October 2017
Thank you. New drive is compatible, have replaced one before. Now I can't get prosess stopped.
Says "Failed to stop rebuild: another rebuild is pending".
I think I'll contact support.
rob Wettengl posted this 11 November 2017
Im having same issue, progress has stalled at 70% and only replaced drive is flashing.  The other drives are not flashing?
