Promise Utility 32-bit App launches but does not display window(s) running macOS 10.14 Mojave
  • 899 Views
  • Last Post 18 June 2018
Barry Sharp posted this 17 June 2018
I'm running 10.14 Mojave and I can launch my Promise Utiulity which BTW is a 32-bit application and it will not display any of its windows for my Pegasus R4, Pegasus2 R6 and Pagasus3 R4.
In addition, as it's a 32-bit application Apple states it's not optimized for Mojave and that 32-bit suppoprt will be dropped in future macOS versions.
Pradeep Chidambaranath posted this 17 June 2018
Hi Barry,
As of now the Pegasus untility is not compatible with MAC OSX 10.14 as the OS is still under beta testing. Kindly try the following to see if you are able to generate the subsystem report using the following commands.
    Open the Mac OS Terminal session: In Finder, go to Applications, then open Utilities, then open Terminal.
    At the "$" prompt, type promiseutil and press Enter. If Promise Utility is installed, this command will change the prompt to "CLIIB>".
    At the "CLIIB>" prompt, type each of the following commands on their own line, pressing Enter after each one:
    subsys -v
    enclosure -v
    ctrl -v
    phydrv -v
    array -v
    logdrv -v
    checktable -l 0
    event
    event -l nvram
Once that is done, then in the Applications folder, open TextEdit, and from File select New Document.
Select All from the Terminal window, and Copy the entire terminal session to your clipboard; then, Paste it into the TextEdit document.
Barry Sharp posted this 18 June 2018
Here's what was displayed following all your instructions...
Last login: Sun Jun 17 07:40:34 on console
Neptune:~ bxs$ promiseutil
Promise Utility
Version: 4.02.0000.10 Build Date: Dec 22, 2017
Type  #    Model         Alias                         WWN                 Seq
hba   1  * Pegasus R4                                  2000-0001-5554-9b1e  5
hba   2    Pegasus2 R6                                 2000-0001-5557-5b1d  3
Totally 2 HBA(s) and 0 Subsystem(s)
cliib> subsys -v
Alias:
Vendor: Promise Technology,Inc.        Model: Pegasus R4
PartNo: F29DS4722000000                SerialNo: M74H12923400161
Rev: A2                                WWN: 2000-0001-5554-9b1e
PDSN: N/A
cliib> enclosure -v
Enclosure Setting:
EnclosureId: 1
EnclWarningTempThreshold: 51C/123F     EnclCriticalTempThreshold: 56C/132F
CtrlWarningTempThreshold: 64C/147F     CtrlCriticalTempThreshold: 69C/156F
Enclosure Info and Status:
EnclosureId: 1
EnclosureType: Pegasus R4
SEPFwVersion: 1.00
MaxNumOfControllers: 1                 MaxNumOfPhyDrvSlots: 4
MaxNumOfFans: 1                        MaxNumOfBlowers: 0
MaxNumOfTempSensors: 2                 MaxNumOfPSUs: 1
MaxNumOfBatteries: 0                   MaxNumOfVoltageSensors: 3
PSU       Status
1         Powered On and Functional
Fan Location        FanStatus             HealthyThreshold  CurrentFanSpeed
1   Backplane       Functional            > 500 RPM         1100 RPM
TemperatureSensor   Location       HealthThreshold   CurrentTemp    Status
1                   Controller     < 64C/147F        59C/138F       normal
2                   Backplane      < 51C/123F        44C/111F       normal
VoltageSensor  Type    HealthyThreshold         CurrentVoltage  Status
1              3.3V    +/- 5% (3.13 - 3.46) V   3.3V            Operational
2              5.0V    +/- 5% (4.75 - 5.25) V   5.0V            Operational
3              12.0V   +/- 8% (11.04 - 12.96) V 12.1V           Operational
cliib> ctrl -v
CtrlId: 1
Alias:
OperationalStatus: OK                  PowerOnTime: 11 hours 42 minutes
LUNAffinity: N/A                       LunmappingMethod: WWN Based
CacheUsagePercentage: 0%               DirtyCachePercentage: 0%
Vendor: PROMISE                        Model: Pegasus R4
HWRev: A2                              WWN: 2000-0001-5554-9b1e
CmdProtocol: SCSI-3
MemType: DDR SDRAM                     MemSize: 512MB
FlashType: Flash Memory                FlashSize: 8MB
NVRAMType: FRAM                        NVRAMSize: 32KB
BootLoaderVersion: 5.04.0000.61        BootLoaderBuildDate: Dec 26, 2016
FirmwareVersion: 5.04.0000.61          FirmwareBuildDate: Dec 26, 2016
SoftwareVersion: 5.04.0000.61          SoftwareBuildDate: Dec 26, 2016
BIOSVersion: 5.04.0000.61              BIOSBuildDate: Dec 26, 2016
SingleImageVersion: 5.04.0000.61       SingleImageBuildDate: Dec 26, 2016
CtrlCPLDVersion: 0.08
DiskArrayPresent: 1                    OverallRAIDStatus: OK
LogDrvPresent: 3                       LogDrvOnline: 3
LogDrvOffline: 0                       LogDrvCritical: 0
PhyDrvPresent: 4                       PhyDrvOnline: 4
PhyDrvOffline: 0                       PhyDrvPFA: 0
GlobalSparePresent: 0                  DedicatedSparePresent: 0
RevertibleGlobalSparePresent: 0        RevertibleDedicatedSparePresent: 0
RevertibleGlobalSpareUsed: 0           RevertibleDedicatedSpareUsed: 0
WriteThroughMode: No                   MaxSectorSize: 4KB
PreferredCacheLineSize: 64 KB          CacheLineSize: 64 KB
Coercion: Enabled                      CoercionMethod: GBTruncate
SMART: Enabled                         SMARTPollingInterval: 58017211 minutes
MigrationStorage: DDF                  CacheFlushInterval: 3 second(s)
PollInterval: 15 second(s)             AdaptiveWBCache: Disabled
ForcedReadAhead: Enabled
PowerSavingLevel: 0                    SpindownType: N/A
IdleTimeToParkRwHeads: Never           IdleTimeToLowerRotationSpeed: Never
IdleTimeToSpinDown: Never
SGPIOBackPlane: Default/Generic (0)    SASReadyLED: Off
SpinUpDelay: 0 millisecond             PowerManagement: Enable
SecurityAdminPassword: N/A
PciFuncAddr: N/A                       PciLinkSpeed: N/A
PciLinkWidth: N/A
cliib> phydrv -v
PdId: 1
Alias:
PhysicalCapacity: 3TB                  ConfigurableCapacity: 3TB
UsedCapacity: 3TB                      LogicalBlockSize: 512Bytes
ConfigStatus: Array0 No.0              Location: Encl1 Slot1
ModelNo: TOSHIBA DT01ACA3
SerialNo: X5AHXGKKS                    FirmwareVersion: MX6OABB0
DriveInterface: SATA 6Gb/s             Protocol: ATA/ATAPI-8
WriteCacheSupport: Yes                 WriteCache: Enabled
RLACacheSupport: Yes                   RLACache: Enabled
SMARTFeatureSetSupport: Yes
SMARTSelfTestSetSupport: Yes           SMARTErrorLoggingSupport: Yes
CmdQueuingSupport: NCQ                 CmdQueuing: Enabled
CmdQueueDepth: 32                      MediumErrorThreshold: 0
Errors: 0                              NonRWErrors: 0
ReadErrors: 0                          WriteErrors: 0
PowerSavingStatus: Full Power          TemperaturePollingInterval: 3 minutes
DriveTemperature: 39C/102F             ReferenceDriveTemperature: N/A
Flags: N/A                             LastUnconfiguredFragement: N/A
PhysicalSectorSize: 0Byte
PdId: 2
Alias:
ConfigStatus: Array0 No.1              Location: Encl1 Slot2
SerialNo: X5AHXENKS                    FirmwareVersion: MX6OABB0
DriveTemperature: 37C/98F              ReferenceDriveTemperature: N/A
PdId: 3
Alias:
ConfigStatus: Array0 No.2              Location: Encl1 Slot3
SerialNo: X5AHY5MKS                    FirmwareVersion: MX6OABB0
PdId: 4
Alias:
ConfigStatus: Array0 No.3              Location: Encl1 Slot4
SerialNo: X5AHY4AKS                    FirmwareVersion: MX6OABB0
cliib> array -v
DaId: 0
Alias: PEG4
PhysicalCapacity: 12TB                 ConfigurableCapacity: 12TB
FreeCapacity: 0Byte                    MaxContiguousCapacity: 0Byte
AvailableRAIDLevels: 0 5 6 10 1E
PDM: Enabled                           MediaPatrol: Enabled
NumberOfPhysicalDrives: 4              NumberOfLogicalDrives: 3
NumberOfDedicatedSpares: 0
UserSetPowerSavingLevel: 0             CurrentPowerSavingLevel: 0
PowerManagement: Enabled
Physical Drives in the Array:
0     1    3TB         471.04KB     OK
1     2    3TB         471.04KB     OK
2     3    3TB         471.04KB     OK
3     4    3TB         471.04KB     OK
Logical Drives in the Array:
LdId Alias          RAIDLevel Capacity  OpStatus
0    PEG4_1_RAID5   RAID5     4TB       OK
1    PEG4_2_RAID5   RAID5     4TB       OK
2    PEG4_3_Stripe  RAID0     1.33TB    OK
Id  OpStatus  PdId CfgCapacity Revertible Type      DedicatedToArray
cliib> logdrv -v
LdId: 0
ArrayId: 0                             SYNCed: Yes
Alias: PEG4_1_RAID5                    TRIMSupport: Not Support TRIM
SerialNo: 000000000000000000000000DF720ACD43FA19AD
WWN: 22a1-0001-5586-ee4b               PreferredCtrlId: N/A
RAIDLevel: RAID5                       StripeSize: 128KB
Capacity: 4TB                          PhysicalCapacity: 5.33TB
ReadPolicy: ReadAhead                  WritePolicy: WriteBack
CurrentWritePolicy: WriteBack
NumOfUsedPD: 4                         NumOfAxles: 1
SectorSize: 512Bytes                   RAID5&6Algorithm: right asymmetric (4)
TolerableNumOfDeadDrivesPerAxle: 1     ParityPace: N/A
CodecScheme: N/A
LdId: 1
Alias: PEG4_2_RAID5                    TRIMSupport: Not Support TRIM
SerialNo: 0000000000000000000000004403C7B5A88BD595
WWN: 228d-0001-5530-ff2a               PreferredCtrlId: N/A
CodecScheme: N/A
LdId: 2
Alias: PEG4_3_Stripe                   TRIMSupport: Not Support TRIM
SerialNo: 000000000000000000000000EE8882FA521891DA
WWN: 22ac-0001-5500-cb0f               PreferredCtrlId: N/A
RAIDLevel: RAID0                       StripeSize: 128KB
Capacity: 1.33TB                       PhysicalCapacity: 1.33TB
SectorSize: 512Bytes                   RAID5&6Algorithm: N/A
TolerableNumOfDeadDrivesPerAxle: 0     ParityPace: N/A
CodecScheme: N/A
cliib> checktable -l 0
Ld Id: 0
No read check table entry available
No write check table entry available
No inconsistent block table entry available
cliib> event
Seq   Device          Severity TimeStamp             Description
0     Ctrl 1          Info     Jun 17, 2018 07:39:47 The system is started
1     SEP 1           Info     Jun 17, 2018 07:39:47 SEP is found
cliib> event -l nvram
2323  Ctrl 1          Info     Jun 8, 2018 14:24:58  The system is started
2324  Ctrl 1          Info     Jun 8, 2018 14:40:58  The system is stopped
2325  Ctrl 1          Info     Jun 8, 2018 14:44:13  The system is started
2326  Ctrl 1          Warning  Jun 8, 2018 15:13:21  Last shutdown is abnormal
2327  Ctrl 1          Info     Jun 8, 2018 15:13:27  The system is started
2328  Ctrl 1          Warning  Jun 8, 2018 15:25:35  Last shutdown is abnormal
2329  Ctrl 1          Info     Jun 8, 2018 15:25:41  The system is started
2330  Ctrl 1          Warning  Dec 31, 1969 16:00:01 Last shutdown is abnormal
2331  Ctrl 1          Info     Jun 8, 2018 15:58:24  The system is started
2332  Ctrl 1          Warning  Jun 8, 2018 16:07:59  Last shutdown is abnormal
2333  Ctrl 1          Info     Jun 8, 2018 16:08:05  The system is started
2334  Ctrl 1          Warning  Jun 8, 2018 16:46:44  Last shutdown is abnormal
2335  Ctrl 1          Info     Jun 8, 2018 16:46:50  The system is started
2336  Ctrl 1          Info     Jun 8, 2018 17:26:21  The system is stopped
2337  Ctrl 1          Info     Jun 8, 2018 17:31:00  The system is started
2338  Ctrl 1          Info     Jun 8, 2018 18:50:18  The system is stopped
2339  Ctrl 1          Info     Jun 8, 2018 19:04:55  The system is started
2340  Ctrl 1          Warning  Jun 8, 2018 19:29:29  Last shutdown is abnormal
2341  Ctrl 1          Info     Jun 8, 2018 19:29:35  The system is started
2342  Ctrl 1          Warning  Jun 8, 2018 20:26:41  Last shutdown is abnormal
2343  Ctrl 1          Info     Jun 8, 2018 20:26:47  The system is started
2344  Ctrl 1          Info     Jun 8, 2018 20:28:35  The system is stopped
2345  Ctrl 1          Info     Jun 9, 2018 06:27:43  The system is started
2346  Ctrl 1          Info     Jun 9, 2018 17:48:51  The system is stopped
2347  Ctrl 1          Info     Jun 9, 2018 17:54:20  The system is started
2348  Ctrl 1          Info     Jun 9, 2018 18:00:43  The system is stopped
2349  Ctrl 1          Info     Jun 9, 2018 18:02:23  The system is started
2350  Ctrl 1          Warning  Jun 9, 2018 18:04:40  Last shutdown is abnormal
2351  Ctrl 1          Info     Jun 9, 2018 18:04:46  The system is started
2352  Ctrl 1          Warning  Jun 9, 2018 19:04:17  Last shutdown is abnormal
2353  Ctrl 1          Info     Jun 9, 2018 19:04:23  The system is started
2354  Ctrl 1          Warning  Jun 9, 2018 19:26:24  Last shutdown is abnormal
2355  Ctrl 1          Info     Jun 9, 2018 19:26:30  The system is started
2356  Ctrl 1          Warning  Jun 9, 2018 20:08:10  Last shutdown is abnormal
2357  Ctrl 1          Info     Jun 9, 2018 20:08:16  The system is started
2358  Ctrl 1          Warning  Jun 9, 2018 20:23:53  Last shutdown is abnormal
2359  Ctrl 1          Info     Jun 9, 2018 20:23:59  The system is started
2360  Ctrl 1          Warning  Jun 9, 2018 20:26:35  Last shutdown is abnormal
2361  Ctrl 1          Info     Jun 9, 2018 20:26:41  The system is started
2362  Ctrl 1          Warning  Jun 9, 2018 20:40:04  Last shutdown is abnormal
2363  Ctrl 1          Info     Jun 9, 2018 20:40:10  The system is started
2364  Ctrl 1          Info     Jun 9, 2018 21:23:42  The system is stopped
2365  Ctrl 1          Info     Jun 9, 2018 21:27:18  The system is started
2366  Ctrl 1          Info     Jun 9, 2018 21:54:29  The system is stopped
2367  Ctrl 1          Info     Jun 11, 2018 13:48:15 The system is started
2368  Ctrl 1          Info     Jun 11, 2018 17:39:32 The system is stopped
2369  Ctrl 1          Info     Jun 11, 2018 17:42:19 The system is started
2370  Ctrl 1          Info     Jun 11, 2018 20:37:18 The system is stopped
2371  Ctrl 1          Info     Jun 12, 2018 05:16:47 The system is started
2372  Ctrl 1          Info     Jun 12, 2018 21:26:55 The system is stopped
2373  Ctrl 1          Info     Jun 13, 2018 05:16:40 The system is started
2374  Ctrl 1          Info     Jun 13, 2018 21:20:13 The system is stopped
2375  Ctrl 1          Info     Jun 14, 2018 05:17:07 The system is started
2376  Ctrl 1          Info     Jun 14, 2018 13:36:12 The system is stopped
2377  Ctrl 1          Info     Jun 14, 2018 17:54:18 The system is started
2378  Ctrl 1          Info     Jun 14, 2018 22:07:13 The system is stopped
2379  Ctrl 1          Info     Jun 15, 2018 05:17:02 The system is started
2380  Ctrl 1          Info     Jun 15, 2018 21:19:58 The system is stopped
2381  Ctrl 1          Info     Jun 16, 2018 05:16:59 The system is started
2382  Ctrl 1          Info     Jun 16, 2018 12:26:10 The system is stopped
2383  Ctrl 1          Info     Jun 16, 2018 13:33:16 The system is started
2384  Ctrl 1          Info     Jun 16, 2018 21:45:52 The system is stopped
2385  Ctrl 1          Info     Jun 17, 2018 07:39:47 The system is started
cliib>
So what was all that about.... Is it simply some data for you to examine ?
