Pegasus32 R6 suddenly powers off / abnormal shutdown – possible Thunderbolt or power issue
  • 1.9K Views
  • Last Post 10 August 2026
Attila S. posted this 07 August 2026
Hi everyone,
I am experiencing a strange intermittent issue with a Promise Pegasus32 R6 connected via Thunderbolt 3 to a Mac mini running macOS Tahoe 26.2.
The Pegasus occasionally shuts down very suddenly while the Mac itself continues running normally.
Most importantly, I was able to verify the shutdown on a security camera recording of the server room. The video clearly shows that the Pegasus is operating normally, with disk activity LEDs flashing shortly before the incident. Then, from one second to the next, ALL LEDs on the Pegasus go out simultaneously, including the power-button LED.
There is no gradual shutdown and no indication that only the Thunderbolt connection is lost. Visually, it looks exactly as if someone had suddenly pulled the power plug from the Pegasus.
The Mac mini itself remains powered on and running during the entire event.
The Pegasus is located in an air-conditioned server room at approximately 20°C, so an external overheating problem seems unlikely.
After restarting the Pegasus I generated a Promise Service Report. The RAID itself looks healthy:
- Overall RAID status: OK
- RAID5, 5 x Toshiba MG10 8 TB
- 1 x Toshiba MG10 8 TB global spare
- All six physical drives: OK
- SMART health: OK
- No read/write errors reported
- No bad blocks reported
- PSU status: "Powered On and Functional"
- Fan: Functional
- Controller temperature: 60°C
- Enclosure temperature: 40°C
- 3.3 V / 5 V / 12 V sensors: Operational
The interesting part is the Promise event log. After the most recent incident it reports:
Aug 5, 2026 18:16:11 – Warning – "Last shutdown is abnormal"
followed a few seconds later by:
Aug 5, 2026 18:16:16 – "The system is started (Thunderbolt)"
There is no normal shutdown, host shutdown, host restart or host unplug event immediately before this abnormal shutdown.
Older entries show that the Pegasus is normally able to distinguish between events such as:
- "The system is stopped by host shutdown"
- "The system is stopped by host restart"
- "The system is stopped by host unplug"
This makes the "Last shutdown is abnormal" entry particularly interesting.
I also checked the macOS logs around the event. The Promise DriverKit extension does not appear to crash. macOS reports the Promise device disappearing from the Thunderbolt/PCIe connection, the volume being unmounted, and the Promise driver subsequently terminating normally. When the Pegasus becomes available again, the driver is loaded again. macOS also reports 0 crashes for the Promise driver.
The Mac itself remained powered on throughout the incident.
The Pegasus is currently connected to an APC Back-UPS Pro 900VA, which macOS recognizes correctly via USB. The UPS reported normal AC operation when checked.
 As a first troubleshooting step I have now ordered a genuine Apple Thunderbolt 3 cable to rule out the existing Thunderbolt cable.
 My main question is:
Has anyone seen a Pegasus32 R6 behave like this – suddenly and completely losing power, with all LEDs including the power-button LED going dark, and subsequently logging "Last shutdown is abnormal"?
Could a Thunderbolt link/cable/controller problem actually cause the Pegasus32 itself to completely power off like this?
Or does the fact that ALL LEDs, including the power LED, disappear instantaneously point more strongly towards an internal PSU/power circuitry problem, or possibly an issue with the external UPS/power supply?
I have the Promise Service Report and can provide additional macOS log excerpts if useful.
Any experience with similar failures would be greatly appreciated.
Frank Bosma posted this 10 August 2026
Hi Attila,
most common cause would be the Thunderbolt connection, the Pegasus 3 and 32 models will shutdown completely and immediately when this connection is lost for whatever reason.
So testing with another Thunderbolt cable is always the first step.
You can also test the other Thunderbolt port on the Pegasus device and on your Mac host if available, preferably direct connect as single device to rule out any other possible interference.
If available also test on another Mac host PC.
If issue remains then there seems to be an issue with the device internals, either PSU that can't provide (enough) power or any component on the mainboard that failed.
In that case Promise needs to exchange the device (or chassis) via RMA procedure if the device is still covered by the 3 year warranty period.
Attila S. posted this 10 August 2026
Thank you, that helps. I have already ordered a new TB3 cable and wait for it to arrive. I did not know, that I could use the other TB port an the device, which I will also try as another port on my Mac Mini. Maybe it is best practice, if I change on thing after another to get an idea, what the problem was. If everything won't help I would like to go for the RMA procedure. One question upfront: When we change the chasis and I keep the discs, will my data be lost when putting them in a new chasis ???
No, your data is safe.
All RAID information is stored on the set of disks themselves there for they can be transferred to any other Pegasus R6 or even R8 chassis, the volume on them will mount normally.
Oh, that's great news !!
But still I would prefer if it was just the cable
