Pegasus2-R4, open schedule will not work
  • 465 Views
  • Last Post 07 February 2018
Palle Jensen posted this 07 February 2018
Hi
I have this unit connected to an iMac27"-5K, running macos 10.13.3. It works fine. I have just completed on session for media patrol. I wanted to put that into a scheduled way, but the Promise Utility freezes on this request, as you may see on screendump.
Do I need to upgrade something? a driver or...???
please advise
Palle
Ok, I had the Utility 4.0000000 and now I updated to 4.0200, from you link, and the scheduler can be set. I expect it will work.
thanks fro fast reply
Palle
Dinesh Kannusamy posted this 07 February 2018
Hi Palle,
Please make sure you have the latest version of the utility. You can also try to uninstall and reinstall the latest utility by accessing the below link
https://promise.com/DownloadFile.aspx?DownloadFileUID=4750
If still the same then please contact Promise Tech support https://promise.com/ContactUS or you can also create a web support ticket in support.promise.com
Thanks..
