Pegasus R6 dead drive due to removal
  • 749 Views
  • Last Post 20 June 2017
Erik Satre posted this 20 June 2017
Hello
I have had the P1 R6 running great for a couple of years. Drive 4 turned red...with an error indication saying drive marked dead due to removal. I remounted the drive and it was able to be rebuilt and was good for a day or so. Then it was marked dead again. Ok so I got two new approved drives for backup. I swapped out Drive 4 and rebuilt assuming the original drive truly dead. Worked fine for a week and then the same marked dead due to removal error. Tried a third replacement and same result.
Anyone have similar issues out there and discovered a solution?
Running mac OS 10.12.3 and latest Pegasus drivers and firmware installed
Devendra Kumar posted this 20 June 2017
Hi Erik,
It looks like there are multiple drive failed in the unit and Rebuild can be possible only with single drive.
Could you please go to https://support.promise.com to register the product and create a new websupport ticket with the latest subsystem report for further assistance.
Go to the below link go download the latest version of the utility.
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=4539
- Open Promise Utility.
- Click the lock symbol on the left bottom corner of the screen to unlock the utility.
Dev
