Pegasus M4 – does it work with OS 27
  • 821 Views
  • Last Post 4 weeks ago
Joerg Frye posted this 4 weeks ago
I have a Pegasus M4 and a Pegasus3 R4 here.
Can I update to the new macOS 27? Will the connection still work after the update? There haven’t been any software or firmware updates for a very long time—are these devices even still supported?
Thanks in advance.
Joerg
R P posted this 4 weeks ago
Hi Joerg,
The Pegasus3 and M4 work fine with Golden Gate and the DEXT driver.
As Apple has made no changes to macOS with regard disk devices, no updates to the driver have been needed.
Emporio Alnino posted this 4 weeks ago
Compatibility with a newer operating system is definitely worth confirming before upgrading, especially when using storage hardware like the Pegasus M4. It would be helpful to know whether Promise has released official driver or firmware updates for OS 27 and whether existing users have tested it successfully. Checking compatibility in advance can save a lot of troubleshooting later. I usually take the same careful approach when trying something new, even when taking a quick break with Slope. Has anyone tested the Pegasus M4 with OS 27 and confirmed that it works reliably?
  • Joerg Frye
Hi RP,
Have you tried it out yourself, or do you have any experience with it? Are you using the devices under OS 27?
And yes, Emporio Emporio Alnino, I completely agree with you on that. Promise really ought to address this and issue an official document regarding it.
