Orange light on the power button and unresponsive
  • 2.1K Views
  • Last Post 27 April 2018
Patrick D posted this 01 August 2017
My Pegasus2 R4 unmounted and the power button turned oragne. Im using OsSierra and the promise utility doenst show any interface window. The view and windows options are grey.
I cant turn on or mount the pegasus and the utility is not working on my Sierra.
Any ideas?
Cheers
Venkatachalam Settu posted this 01 August 2017
H Partick,
It looks like this issue needs to be analyzed with the help of subsystem report of the unit to find out the problem.Kindly follow up your existing case # 20170731200538S.
they seem to be separated issues, how come is the pegasus utility not working or showing any active interface window for the MacOSSierra?
Hi Patrick,
There are many scenerios where you can face the Promise Utility not responding issue. I beleive it's not MacOSx issue.
What should I do to fix the utility? so we can start focusing on the RAID
Hi Partick,
Kindly follow up the support case # 20170731200538S.
Andrew Dean posted this 01 August 2017
I am having the same issue.
Pegasus2 R Series 8-bay enclosure with 8 x 4TB SATA HDD; PROMISE hardware RAID; Thunderbolt2™ technology; 1 meter Thunderbolt cable.
Strange thing is the system report has correctly ID'd the raid
Pegasus2-R:
  Vendor Name: Promise Technology, Inc.
  Device Name: Pegasus2-R
  Vendor ID: 0x2
  Device ID: 0x9
  Device Revision: 0x3
  UID: 0x000200000012AD40
  Route String: 1
  Firmware Version: 19.2
  Port (Upstream):
  Status: Device connected
  Link Status: 0x2
  Speed: Up to 20 Gb/s x1
  Current Link Width: 0x2
  Cable Firmware Version: 0.1.23
  Link Controller Firmware Version: 0.13.0
  Port:
  Status: No device connected
  Link Status: 0x7
  Current Link Width: 0x1
Pradeep Chidambaranath posted this 01 August 2017
Hi Andrew,
Please go to https://support.promise.com and register the product under your name and create a support ticket with the latest subsystem report for further assistance.
- Open Promise Utility.
  - Click the lock symbol on the left bottom corner of the screen to unlock the utility.   - Click on save service report button to save the subsystem report.   Regards Pradeep C
Patrick D posted this 12 December 2017
Hi I'm still with the orange light and nothing mounted to the computer. Also the Promisse app there is no display window. Any help with this? not even the promisse app is working....
Mario Cavalli posted this 27 April 2018
I'm experiencing exactly the same problem.
Installed macOS update to High Sierra 10.13.4 on return from vacation.
On restarting iMac (Retina 5K, 4Ghz Intel Core17), Pegasus Promise failed to mount, power button illuminated ORANGE, will not power down, or respond.
Have installed Promise Utility 'R_Promise_Utility_402000010', allowed extension under Security & Privacy and rebooted. Still not mounting and nothing showing in Promise Utility either.
Have submitted issue to Support Center and awaiting response but meanwhile, all my work and data is inaccessible. Uncertain how to proceed.
Any help or advice gratefully received.
PS
Since writing the above, I found and followed this advice:
- Shutdown the pegasus using the power button
- If it's not working unplug the power cable
However, having powered down the iMac, removed power cable and drives then rebooted the Mac, the unit would not power up at all, either automatically or by depressing the power button.
All connections have been checked, alternate thunderbolt ports tried at both ends, rebooted several times, with and without drives replaced always in the correct order but the unit is showing no sign of power. I am therefore unable either to use the Promise Utility or generate a service report.
A follow up question, if the fault is with the unit itself, can I purchase a replacement 4 bay unit and insert the four drives from this faulty one?
Again, thank you in anticipation.
Mario
