No connection to SANLink2 with new iMac Pro and Thunderbolt adapter
  • 775 Views
  • Last Post 21 March 2018
Brian Pitre posted this 06 March 2018
I have installed the SANLink2 10BaseT on a new iMac Pro using the Thunderbolt 3 to Thunderbolt 2 adapter.
The SANLink has worked for years on my last computer but is not working on this one. I have updated the drivers to the most recent drivers available and still no connection.
James Adkins posted this 21 March 2018
Sadly have tried that with no success. Even tried older installs in case it was the latest one causing issues but still no link to the device.
Thanks for the help
James
Brian Pitre posted this 20 March 2018
Hey James,
What finally worked for me was running the install again and then checking the security area in system prefs after the install was complete. I was able to confirm the security of the installed software, and everything worked fine after that.
James Adkins posted this 20 March 2018
I have a similar problem to the above thread; this time using a MacBook Pro (15-inch, 2016) again with the thunderbolt adaptor. My device is available on the thunderbolt Bus and there is a 1 in the kext database. However, both the app and OSX cannot access the network interface.  Looking in system information extensions page shows the SanLink2 Device but not as loaded. I have tried telling the terminal to load the SanLink2; it does load but still no network cards visible in OSX or in the Sanlink utility.
Any help greatly appreciated.
Output from Terminal - "/KextPolicy '.dump kext_policy' | grep promise
INSERT INTO kext_policy VALUES('268CCUR4WN','com.promise.SANLink-FC',1,'Promise Technology Mobile Apps',1);"
P B posted this 06 March 2018
1. Is the device visible within the Thunderbolt Bus?
Post the output of the command below:
system_profiler SPThunderboltDataType | grep -i sanlink
2. If the device is available within the Thunderbolt bus, have you checked if the kernel extension loaded?
It could be possible that it was blocked due to User Approved Kernel Extension Loading. (Introduced in macOS 10.13)
You can refer more about User Approved Kernel Extension Loading here:
https://support.apple.com/en-us/HT208019
3. Please post the output of this command:
sqlite3 /private/var/db/SystemPolicyConfiguration/KextPolicy '.dump kext_policy' | grep promise
4. If there is a 0 in the kext database, then the kernel is not allowing the driver to load:
INSERT INTO kext_policy VALUES('268CCUR4WN','com.promise.driver.SANLink2-10GE',0,'Promise Technology Mobile Apps',8);
This was discussed in a similar post (Discusses User Approved Kernel Extension Loading):
https://forum.promise.com/thread/sanlink2-8gfc-driver-no-go-with-10-13/
Devendra Kumar posted this 06 March 2018
Hi Brian,
We have not tested such configuration using thunderbolt adapter with Sanlink2. Please check the compatibility list if thunderbolt adapter is listed in the list.
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=4272
