Failed firmware upgrade - how to solve ?
  • 813 Views
  • Last Post 03 January 2025
Philippe ASTIER posted this 24 April 2018
Hi all,
I've had a bad firmware update that ran into the Pegasus 3 R6 turning Orange. It's not visible from Promise Utility anymore, still visible on Thunderbolt bus.
How do you solve it (case has been opened) ?
History :
- unpack array,
- upgrade Utility to latest version (4.02.0000.10 (C01))
- firmware upgrade from Utility NEVER finishes
- firmware upgrade from CLI fails, see below.
- Array is not visible anymore.
Host : MB Pro Retina with High Sierra.
cliib> ptiflash -f /Users/philippe/Downloads/R_SI_600000018.img
Start transferring image, please wait ...
Flash image has been successfully transferred.
Start flashing image, please wait ...
Error (0x105): operation failed. Usually due to some system error
Jacob Brasch posted this 03 January 2025
Have a similar problem. Tried to update firmware on my promise pegasus3 r6 and it failed at 50% now I have no contact to the raid and can not retry. It’s not possible to open a case because it’s not covered by warranty anymore. I’m considering buying a promise32, but the risk of this happening again is holding me back. Is possible to connect it somehow and upgrade firmware or is it dead?
No solution yet, which is why I was asking for any idea...
The unit simply won't show in promiseutil (GUI or CLI), despite being connected and visible through Thunderbolt...
arunkumar b posted this 24 April 2018
Hi Philippe,
We found that you have opened case.Please follow the case.
