Driver not unloaded issue on Win10
  • 969 Views
  • Last Post 25 October 2017
Yves Hsu posted this 20 October 2017
Hi all,
I am using Macbook pro with Belkin USB-C dock. I use it for several months without any issue.
But recently it shows some drivers can not be loaded successfully due to unsufficient PCIe resource.
I tried to debug it and I found it only happen if I connect Pegasus 3 before this Belkin dock.
Even though I already remove the Pegasus3 device, it still can not load Belkin dock driver successfully.
I have to reboot it and everything shows okay. So I think the Pegasus3 driver is not unloaded when it is removed.
Can it be fixed?
Yves Hsu posted this 25 October 2017
One more information. If I don't launch Pegasus Utility, this issue will not happen.
So it seems Pegasus utility will keep driver from unload after unplug.
Hi Pradeep C,
The driver package is the same as I used.
Pradeep Chidambaranath posted this 20 October 2017
Hi Yves,
Have you tried reinstalling the drivers to see how it works. Click the below link to download the drivers.
Pegasus3 Series Driver for Windows - https://promise.com/DownloadFile.aspx?DownloadFileUID=4542
