I've got a Pegasus 2R4 with a volume that is formatted with APFS that is causing continual kernel panics on any system it touches - MacBook Pro 15 through an Apple Thunderbolt 3 to Thunderbolt 2 adapter; a iMac Pro with the same adapter; or the Thunderbolt 2 cable into a MacPro. With every one it takes about 3 - 10 minutes to freeze the machine and when I reboot I see that there's been a kernel panic.
I've scrubbed the MacPro clean to a virigin High Sierra install. I've also tried it with-and-without the Pegasus drivers and firmware is the latest version.
Anyone else experiencing somegthng similar? My whole personal and working life is on those disks and I really need to get access.
Continual kernel panics Pegasus 2 R4 when mounting APFS volume in MacOS High Sierra 10.13.3
- 631 Views
- Last Post 01 February 2018
Thanks for your response. I'll raise a ticket, however:
1. Using the latest drivers (as I mention in my post)
2. Can't run Mac System Profiler with drive attached as it crashes as soon as the drive mounts.
3. Can't rom Promise Utility report with drive attached as it crashes as soon as the drive mounts.
I've also booted into Online Recovery mode and run Disk Repair on the volume.
Hi James,
Could you kindly install the latest Pegasus2 dirvers for High Sierra to see how it works.Go to the link below to install the latest version of drivers.
If you still have issues after installing the latest drivers, please create a support ticket with the latest subsystem report, MAC system profiler and the panic logs for further investigation.
- Open Promise Utility.
Follow the below steps to save the MAC system profiler.
Mac system profiler (Click Apple Icon > About this Mac > More info > System Report > Choose 'File' & 'Save')
Go to the link below to get the step by step instruction on how to save the panic logs.
https://support.apple.com/en-us/HT201753
