Best RAID with two Promise Pegasus systems
  • 772 Views
  • Last Post 11 January 2018
Emile Meuffels posted this 11 January 2018
I have two Promise Pegasus 2 systems, a R6 with 6x2 TB disks and a R4 with 4x3 TB disks.
At the moment both run on RAID5 with 10TB available on the R6 and 9TB available on the R4.
I would like to use one of them as a backup for the other. Am I correct in assuming that I could use RAID0 for both and have two 12TB disks as safety is not an issue if I use one as a backup disk?
Thanks for your advice!
Emile
Devendra Kumar posted this 11 January 2018
Hi Emile,
Yes, you will have recreate new array and restore data.
Thank you for your answer!
If I select RAID 0 and one drive fails; can put in a new drive, reformat and put the backup back?
Emile
Hi Emile,
You can create RAID 0 however if any one drive failed the logical drive will go offline. Make sure there should data backup.
