Bad Hard Drive - Help!
  • 1.2K Views
  • Last Post 06 May 2018
Jauvid Ayadi posted this 04 May 2018
I have a 4 HD system. One of my hard drives has a red light. Is there a link as to how to change the drive? And after I do that will all my files still be there? Or do I need to do additional steps? Sorry if I sound ignorant.
Raghuraman Kannan posted this 04 May 2018
Hi Jauvid,
I would recommend you to register yourself as a user @ https://support.promise.com/ and open a case with the service report. We will review the logs and will let you know if replacing the drive would fix the problem.
1) Open Promise Utility.
4) Click on save service report button to save the subsystem report and attach it to the case
Jauvid Ayadi posted this 05 May 2018
when I run save service report the software stops working and restarts! When I look at the dashboard 3 drives have minor (bad sector) and one drive has major (logical drivr set to critical) issue
Pradeep Chidambaranath posted this 06 May 2018
HI Jauvid,
Kindly follow the below KB article, to generate the complete report through Terminal.
https://kb.promise.com/thread/pegasus-information-requirements-when-contacting-technical-support/?order=all#comment-f85bb780-41a9-461e-abd8-a5b6009da9f1
Jauvid Ayadi posted this 06 May 2018
I have attached the report from Terminal to my post
Hi Jauvid,
I do not see any files attached here. Could you kindly go to https://support.promise.com to create a support for further assistance. If you have already created  a case, could I get the case ID to assist you further.
