1830i login problem
  • 919 Views
  • Last Post 17 October 2017
Marcin Kręgiel posted this 16 October 2017
Hi
I don't know the IP address of the VessRAID’s Management Port. I was trying to login by serial port, but after I press <ENTER> I only got
cli>
and that's it.
Manual says:
2. Press Enter once to launch the CLI.
3. At the Login prompt, type
administrator and press Enter.
4. At the Password prompt, type
password and press Enter.
Wher is "Login prompt"?
I found in manual:
Logging Back Into the CLI and CLU
To log into the CLI and CLU after a manual logout:
1. At the cli> prompt, type
login followed by your user name and press Enter.
2. At the Password: prompt, type your password and press Enter.
3. At the username@cli> prompt, type
menu and press Enter to open the CLU
but after that (I mean cli> login administrator <ENTER>)  I got "invalid command" message.
Richard Oettinger posted this 16 October 2017
Hi Marcin,
What do you get if you type "enclosure" <Enter>?
~ Richard
I didn't save it, but it was some report about interfaces and something looks like MAC addresses... I can go tomorrow and get any logs you need
That sounds like you are not connecting to the Vess controller, the "cli>" prompt is for the backplane.
Are you using the correct PROMISE serial cable?
I thought I did, I made it myself:
I thought if I got cli>, that means communication is OK
Good try - but that is not the correct connections for a PROMISE serial port. 8^)
Try this:
I think that was my first try of making cable, but I'm not sure. I will try that again and see if it helps.
Marcin Kręgiel posted this 17 October 2017
Hi Marcin,
~ Richard
My old cable:
 Time since system powerup: 0 day  21 hours 25 minutes 51 seconds
 Enclosure            : SAS RAID 2U-12 Bay
 Serial Number        : Cx20y-123456
 I/O Module ID        :  1              Max I/O Module Cnt    :  1
 Firmware Version     : 03.04.0000.00   I/O Module Role       : Primary
 Max HDD Slot         : 12              Max Connectors        :  2
 Max PSU Cnt          :  0              Max Fan Cnt           :  0
 Max Temp Sensor Cnt  :  0              Max Voltage Sensor Cnt:  0
 Thermal management                                            : Enabled
 Allow shutdown the system when critical temperature is reached: Yes
 Current minimum fan speed                                     : Low
 Controller temperature threshold: C/32F (critical) C/32F (warning)
 Expander SAS Addresses:
 STP Base  50 00 15 5D 21 12 22 00
 SSP       50 00 15 5D 21 12 22 3E
 SMP       50 00 15 5D 21 12 22 3F
 Attached SAS Addresses:
 Slot1     50 00 15 5D 21 12 22 00
 Slot2     50 00 15 5D 21 12 22 01
 Slot3     50 00 15 5D 21 12 22 02
 Slot4     50 00 15 5D 21 12 22 03
 Slot5     50 00 15 5D 21 12 22 04
 Slot6     50 00 15 5D 21 12 22 05
 Slot7     50 00 15 5D 21 12 22 06
 Slot8     50 00 15 5D 21 12 22 07
 Slot9     50 00 15 5D 21 12 22 08
 Slot10    No Device Attached
 Slot11    No Device Attached
 Slot12    No Device Attached
 CN#1      50 00 15 53 07 9A 80 00
 CN#2      No Device Attached
cli>
new cable:
EDIT: it works perfectly. Thanks again.
  • Richard Oettinger
