Will it work
  • 3.5K Views
  • Last Post 28 September 2017
Ron Whitaker posted this 12 March 2016
GA-Z170X-Gaming 7-EU (rev. 1.0)
I have the above system that supports thunderbolt connection. I can only find a usb 3.1 type c connector on back. Will the pegasus2 r4 connect.
Philip Wong posted this 12 March 2016
USB 3.1 type C connector is new design for supporting Thunderbolt 3 device.
Promise Pegasus2 r4 is a Thunderbolt 2 design. It doesn't support  USB 3.1 type C connection.
Jerry Case posted this 12 March 2016
Thunderbolt 3 is provided over USB-C type connector.   We have not seen any production TB3/USB-C to TB2/DisplayPort style adapters.  However adapters are coming soon from various manufacturers.
When the USB-C to Thunderbolt 2 adapters are available, we may test with the Pegasus2 family to establish compatibility. Please keep an eye on the compatibility list published in our download center.
At this time--Pegasus2 is not supported and it’s unknown if it will be in the future.  Once these adapters are available we will assess them then determine compatibility.
-Jerry
Promsie Technology
Sashi Rajamahendran posted this 16 March 2017
Is anyone using a USB-C to Thunderbolt 2 adapter on a Pegasus R2?
Pradeep Chidambaranath posted this 16 March 2017
Hi Sashi,
We have not tested USB-C to thunderbolt 2 converters. It might work or it might not work. We do not have any official compatibility list for this yet.
Sashi Rajamahendran posted this 09 April 2017
I tried the apple thunderbolt to USB-c converter. It does not work. The drive turns on and off with the machine, however the Pegasus utility doesn't detect the drive.
Sashi Rajamahendran posted this 10 April 2017
Appologies, I made the mistake of repeating what Promise support told me.
It does in fact work.
Out of interest the motherboard in question is the Gigabyte Aorus Z270X - GAMING 7
  • TIANTZER CHAO
TIANTZER CHAO posted this 28 September 2017
Hello, what do you mean "in fact work".
The I have same situation like you, but my doesn't work like turn on for seconds then turn off
Sashi Rajamahendran posted this 28 September 2017
Hi, have you installed the thunderbolt drivers for your gigbayte board?
