Vtrak E610f converted to an ethernet connection
  • 824 Views
  • Last Post 02 May 2017
Josh Bullock posted this 02 May 2017
Hello.  I have a Vtrak currently on site and I would like to be able to access it via a network connection or a windows box.  Is there any way to do that?
Any type of converter box that would convert fiber channel to network?
Richard Oettinger posted this 02 May 2017
Hi Josh,
The only way to do that is to connect it to a computer and use that to share it out on the network...
~ Richard
So I have it currently connected into a Mac.  How would I go about sharing it over the network so that a Windows 2012 Server can connect to it?
System Preferences -> Sharing
Check FIle Sharing, select the folders to share (the VTrak disk on the Mac, for example)
Set the User and options.
Mount it at: smb://<Mac IP>
