so I got a VessRaid 1840i which works fine so far but everytime the system is disconnected from the power it "forgets" it's management and iSCSI IP address. Everything else like mailserver-IP, disk arrays, password, etc... is saved correctly and applied after the system is reconnected to power.
So whenever it has no power for some short amount of time (less than 1h but I don't know exactly) I need to reconfigure it's management and iSCSI IP address via serial. If I shut it down (poweroff) and turn it back one after a while, the IPs are not reset and it works perfectly.
The unit has a backup battery which is OK according to the VessRaid.
Does the VessRaid have an extra CMOS Battery which might be emtpy or does someone know the cause of the problem?
Thank you very much,
Best Regards Flo
