Using SSDs on Pegasus3 r8
  • 1K Views
  • Last Post 05 June 2017
Mehmet Kayaalp posted this 19 April 2017
I am interested in purchasing a Pegasus3 R8 if I could install 2TB SSDs, but the only three devices that are listed in the Pegasus3 compatibility list v1.1 are three Toshiba products and although the header says SATA/SSD, none of them is an SSD.
So here is my question: Does Pegasus3 R8 support any SSD, e.g., Crucial 2TB CT2050MX300SSD1?
Raghuraman Kannan posted this 20 April 2017
Hi Mehmet,
We will check and get back to you with an update on this.
Please wait .
Mehmet Kayaalp posted this 23 May 2017
Hi Raghuraman,
Thank you for your reply. I have been waiting patiently for the update on this issue but I soon need to act and make a purchasing decision on a DAS or NAS device. I would appreciate if you could let us know when would an update be available.
Mehmet Kayaalp posted this 02 June 2017
Given that there is no follow up response, I presume that the tests of SSDs on Pegasus3 did not yield a positive result that is reportable here.
Raghuraman Kannan posted this 05 June 2017
Hi Mehmet,
Apologise for the delayed response.
We have tested these units with few SSD drives and the Samsung drives have been included in the latest compatible list.
You can use any SSD drives but for optimum performance, we recommend tested drives.
You can download it here.
https://promise.com/DownloadFile.aspx?DownloadFileUID=4534
Mehmet Kayaalp posted this 05 June 2017
Thank you!
