PLEASE CAN SOMEONE HELP: Using promise pegasus 2 and 3 simultaneously
  • 400 Views
  • Last Post 17 July 2019
Carlos Ruiz posted this 06 June 2019
Hi
We work on documentary and we use a Pegasus 2 R6 on a mac pro with thunderbolt 2
We are getting a Pegasus 3 R6
We need to use both discs Pegasus 2 and 3 on the same mac pro with thunderbolt 2
As we understand we need to installed a new drive for the Pegasus 3 and it should work on the mac pro with an adaptor - thunderbolt 2 to 3? Is that right?
If we installed this new drive for Pegasus 3 does it affect the drive for Pegasus 2?
Can we work wiht both discs on this computer or is there a possiblity of conflict in terms of drives?
Is there any issues we shold be awre of using a Pegasus 3 on a thunderbolt 2 via an adaptor?
Thanks very much
Carlos Ruiz
PROMISE Technology Inc. posted this 17 July 2019
Hi Carlos,
Apple makes a ThunderBolt 3 to ThunderBolt 2 adapter that should do what you need.
  • https://www.apple.com/shop/product/MMEL2AM/A/thunderbolt-3-usb-c-to-thunderbolt-2-adapter
A Pegasus 3 will work with an older MAC as long as the Pegasus 3 driver can be loaded. The Pegasus 3 R4 driver is for...
  • Mac OS X 10.12 or above
I have tested this with the Apple adapter, a Pegasus 3 R4 and macOS 10.13. It works as expected.
It might be best to connect each Pegasus to a different ThunderBolt bus, whether they will work daisychained I do not know.
