Speed up Pegasus2 R4 with SSDs?
  • 1K Views
  • Last Post 26 May 2017
Julian Giardinelli posted this 25 May 2017
I am trying to get faster speeds out my Pegasus2 R4 (2TBx4).  According to both AJA and Blackmagic speedtest utilities, I am getting an average of 383MB/s Write & 300MB/s Read on a 4GB test file.  Is this normal?  I was expecting a little faster, especially when reading.
My settings are as follows:
Host: MacPro (2013) w/32GB RAM running OSX 10.12.5
Spotlight is off
Raid 5
Latest firmware
1MB Stripe Size
Forced Read Ahead Enabled (Controller Settings)
Volume is 20% full
Is it possible to replace the stock hard drives that came with my Pegasus2 R4, with SSDs?
If so, do they have to be 3.5" or can I use 2.5" SSDs?
What are the recommended SSDs? (Same as for the Pegasus2 M4?)
Thank you...
Karthik K posted this 26 May 2017
Hi Julian,
SSD drives are not compatible with Pegasus2 R4 units.SSD drives are compatible only with Pegasus2 M4 units.
In order to find the exact problem , please follow the below steps and send us the service report
- Open Promise Utility
- Click on save service report button to save the subsystem report and attach it .
We will check the report and let you know if there are any issues.
For Immediate assistance , you can always open an case at support.promsie.com or you can call us at 408-228-1500 .
Karthik
Julian Giardinelli posted this 26 May 2017
OK.  Report saved but your website will not allow me to upload the file.  "File extension not allowed" error.  I will try a support request.
