replacement power supply for Pegasus2
  • 522 Views
  • Last Post 03 August 2021
W Ko posted this 02 January 2021
My powersupply for my Pegasus2 has died.  Does anyone know where I can buy a replacement one?
Thank you!
Paul Kerry posted this 01 March 2021
Bascially Promise won't tell you this because they want you to fork out 1000s of dollars to buy there new model.
What I would do is find out the model number and find the part on ebay.
I found this one it took me all of 2 seconds to find it, I am sure there are other suppliers
but un like promise I actually help people.
https://www.ebay.com.au/itm/PSU-Power-Supply-for-Promise-Pegasus-2-R4-R6-R8-250W-1U-PSU-24pin-12pin/152603942091?hash=item2387e75ccb:g:-ZwAAOSwux5YNZNf
  • Thomas Agatz
  • 坤 钟
Gautham Sakthi posted this 03 January 2021
Hello W Ko,
The power supply used in the Pegasus unit is not field-replaceable. Also this is an EOSL unit please refer to below link,
https://www.promise.com/Support/warranty/EOSL
I would recommend you to upgrade to the newest version of the Pegasus series and you could still use the old drives on the new unit and have access to data.
坤 钟 posted this 03 August 2021
They stopped supporting the old version of the software and hardware, which is very unfair to the purchaser. he only hope that you can upgrade to the new model of the machine as soon as possible.
R P posted this 03 August 2021
No vendor updates the firmware or software for EOL products.
But Pegasus drivers and the Pegasus Utility are backwards compatible with older Pegasus models.
Go to the Pegasus32 downloads page and download the latest driver and Pegasus Utility and it will work even with your Pegasus 1. The latest driver is also compatible with both M1 and Intel MACs.
