My powersupply for my Pegasus2 has died. Does anyone know where I can buy a replacement one?
Thank you!
Thank you!
Hello W Ko,
The power supply used in the Pegasus unit is not field-replaceable. Also this is an EOSL unit please refer to below link,
https://www.promise.com/Support/warranty/EOSL
I would recommend you to upgrade to the newest version of the Pegasus series and you could still use the old drives on the new unit and have access to data.
