I have a Promise Pegasus R8 24TB purchased on 02/12/2015. The hard drives are Seagate 3000GB, Model ST3000DM001, 7200RPM, Firmware:CC27.
What are the current replacement hard drives and what is the exact procedure to replace a hard drive?
Please refer to below document for list of hard drives,
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6600
Here is the rebuilding Steps for New Drive :
- Make sure you hot-plug the new drive
- Click on "Physical Drive" list in the Utility and make sure the replacement drive is showing up in the list
- The status of that drive should be "Unconfigured"
- If the status is "Passthru", then unlock the Utility and click on settings for that drive and change it to "Unconfigured"
- Confirm the settings .
- Then click on "Background Activities"
- Click on the Start button next to the Rebuild.
- Select the Source drive and the Target drive and Start the process.
