One of the suggested compatible drive for the Pegasus2 R4 is the Segate Barracuda ST3000DM001. however, this has now gone end of life and been replaced with the Seagate Barracuda ST3000DM007 which looks very similar. can you confirm if this is suitable (I am thinking of replacing all 4 drives) and creating a new array.
Replacement drive for pegasus2 R4
- 150 Views
- Last Post 01 March 2020
Pippa Toogood
posted this
28 February 2020
Raghuraman Kannan
posted this
01 March 2020
Hi Pippa,
You can use any SATA drives in the unit as long as it is detected.
We checked the specs for that drive, it is very similar to the drive that you currently have. It should work.
