Replacement disc for Pegasus3 r4 16tb array
  • 66 Views
  • Last Post 14 April 2020
Andrew Morgan posted this 11 April 2020
I have Pegasus3 r4 16tb with 4 Toshiba MD04ACA4 SATA HDD.  Do not know whether they are 128 or 256. Not able to find Toshiba replacement to have for "just in case" a disc fails. What replacement disc would be best? I am currently looking at WD4005FZBX WD Black 4TB performance Desktop HDD 7200 RPM SATA 6 Gb/s 256MB cache 3.5 inch.  Would this work? Any suggestions?
Raghuraman Kannan posted this 14 April 2020
Hi Andrew,
Pegasus 3 units have 3 years warranty from the date of purchase . If this unit is under warranty, please open a case at https://support.promise.com/ with the latest report. We will advise you on next step.
1) Open Promise Utility.
If not under warranty, refer to the below link and download the compatibility list. Any drives in the list would work.
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6425
