Recover Logical Drive Pegasus R4 After Power Cut
  • 1.3K Views
  • Last Post 06 December 2024
Tony Coombes posted this 02 December 2024
I have an old but trusted Pegasus R4. I had a power cut overnight and the Promise Utility shows that my logical drive has been placed offline. Is there anyway to recover this as I have a lot of data on it?
R P posted this 02 December 2024
Hi Tony,
There is not enough information in the screenshot to tell.
Please generate a service report, zip it, and attach it to your next post.
This Knowledge Base article shows you how to generate a service report.
Tony Coombes posted this 03 December 2024
Trying to upload, but I get "File extension not allowed"
R P posted this 03 December 2024
Hi Tony,
That's why you have to zip the file. It says to zip the file in my original post.
I have zipped the file, but I still get 'File Extension Not Allowed"
I have tried two types of compression software
Hi Tony,
I take taken the issue to the forum IT, they will allow zips. Stay tuned, it probably won't be done until tomorrow.
R P posted this 04 December 2024
Hi Tony,
Another forum poster has just successfully attached a zipped service report, so it works now.
Please attach a zipped service report to one of your posts, and please update the forum so I know about it.
Tony Coombes posted this 04 December 2024
File uploaded
R P posted this 05 December 2024
Hi Tony,
It looks like all the disks went offline at the same time.
185 Dec 01, 2024 23:22:45   Major       PD  4 Physical Disk is marked as DEAD due to removal
186 Dec 01, 2024 23:22:45   Major       LD  0 Logical drive has been set to critical            2276-0001-557E-4618
187 Dec 01, 2024 23:22:45   Major       PD  2 Physical Disk is marked as DEAD due to removal
188 Dec 01, 2024 23:22:45   Major       LD  0 Logical drive has been placed offline. Possible Data Loss 2276-0001-557E-4618
189 Dec 01, 2024 23:22:45 Warning       PD  4 Physical Disk has been removed
190 Dec 01, 2024 23:22:45 Warning       PD  2 Physical Disk has been removed
191 Dec 01, 2024 23:22:45   Major       PD  3 Physical Disk is marked as DEAD due to removal
192 Dec 01, 2024 23:22:45   Major       PD  1 Physical Disk is marked as DEAD due to removal
193 Dec 01, 2024 23:22:45 Warning       PD  3 Physical Disk has been removed
194 Dec 01, 2024 23:22:45 Warning       PD  1 Physical Disk has been removed
However PD4 went offline first and we will assume it is stale.
The procedure from here is to bring PD1,2 and 3 online.
To do this you need the CLI, to access the CLI open a terminal and enter promiseutil.
These are the CLI commands.
phydrv -a online -p 1
phydrv -a online -p 2
phydrv -a online -p 3
At this point the LD should be online but critical, the volume should mount. After it mounts open the Volume and check that your files are visible. If they are, we can proceed to the next step and start a rebuild to PD4.
First, reboot the Pegasus.
After rebooting, the CLI command to start a rebuild is...
rb -a start -d 0 -s 3 -p 4
You can monitor rebuild progress from the Promise Utility Background Tasks.
Also be advised that PD3 SMART data shows some issues. If you don't have a spare replacement disk onhand, getting one would be a good idea.
Tony Coombes posted this 06 December 2024
Fabulous advice, thank you. Worked a treat. All back no data loss, all drives health 100%
