R8 Mac mini m1 no mount no driver load
  • 805 Views
  • Last Post 07 December 2021
Chris Brown posted this 06 December 2021
just delivered and connected
bigSur 11.6
ran the install as per the documentation
downloaded and install driver 3.4.14
R_MacDrv_V6_2_17
invisible, no mount
PromiseSTEX listed in extensions (attachment)
tried the below
Last login: Mon Dec  6 13:47:44 on console
### ~ % kextstat | grep -i stex
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
####~ % sudo kextload /System/Library/Extensions/PromiseSTEX.kext
Password:
Executing: /usr/bin/kmutil load -p /System/Library/Extensions/PromiseSTEX.kext
Error Domain=KMErrorDomain Code=71 "Unable to resolve dependencies: Could not find dependency candidate matching requested extension: "Kext com.promise.driver.stex v6.2.13 in executable kext bundle com.promise.driver.stex at /System/Library/Extensions/PromiseSTEX.kext" UserInfo={NSLocalizedDescription=Unable to resolve dependencies: Could not find dependency candidate matching requested extension: "Kext com.promise.driver.stex v6.2.13 in executable kext bundle com.promise.driver.stex at /System/Library/Extensions/PromiseSTEX.kext}
R P posted this 06 December 2021
Hi Chris,
Inbox drivers are in the /System/Library/Extentions folder, M1 MACs do not have an inbox STEX driver.
If you installed 6.2.17, it will be in /Library/Extentions folder.
Try running...
sudo kextload /Library/Extensions/PromiseSTEX.kext
Hi RP.
thanks for reply
well the Promise download  page seems to indicate they do; lost in translation?
pic attached
pic also of library/extensions
thanks
Last login: Mon Dec  6 14:12:04 on ttys000
#### ~ % sudo kextload /Library/Extensions/PromiseSTEX.kext
Password:
Executing: /usr/bin/kmutil load -p /Library/Extensions/PromiseSTEX.kext
Error Domain=KMErrorDomain Code=27 "Extension with identifiers com.promise.driver.stex not approved to load. Please approve using System Preferences." UserInfo={NSLocalizedDescription=Extension with identifiers com.promise.driver.stex not approved to load. Please approve using System Preferences.}
#### ~ % kextstat | grep -i stex
Hi Chris,
  • Error Domain=KMErrorDomain Code=27 "Extension with identifiers com.promise.driver.stex not approved to load. Please approve using System Preferences." UserInfo={NSLocalizedDescription=Extension with identifiers com.promise.driver.stex not approved to load. Please approve using System Preferences.}
It says that the STEX driver is not approved to load.
There are two steps needed for a driver to load, the first is to enable third party drivers, that process is shown in the PDF with the driver.
You also have to give each driver permission to run in System Preferences > Security & Privacy. In the General tab there should be a button to allow a driver from Promise to load.
Chris Brown posted this 07 December 2021
ok, finally mounted
thanks
