I have an R8 24TB. Last week, a single drive light turned red and Promise Utility labeled the drive "Dead". The array still mounted, but I decided I should just turn it off until an identical replacement drive arrived. I just replaced the drive, expecting to follow the typical instructions for rebuilding the new drive. I turn the unit on, and now ALL of the drives are red and are marked "Dead" in Promise Utility. Please tell me I haven't lost all of my data! I'm hoping I did something wrong...please? Any help appreciated. Thanks, Jack
R8 drive replacement.
- 469 Views
- Last Post 13 February 2019
- Topic Is Solved
I just looked in the NVRAM Events log and noticed "Physical Disk is marked as DEAD due to removal." That reminded me that before installing the new drive, I removed each of the other drives, one at a time, to clean the buildup of dust within the housing. Is that all? I see no way within the software to "unmark" a drive as dead. Is there a recommended procedure via Terminal (I'm on OSX, High Sierra)?
1. You should never remove drives while they're in an operational state.
2. Please review the following forum where this was answered:
https://forum.promise.com/thread/r4-array-bad/
If you require technical support, please create a case via https://support.promise.com
Thanks, that worked and it's rebuilding now. I had powered down before removing the disks...never thought that would cause a problem...but now I know!
