R6 / Capacity lower than physical capacity
  • 180 Views
  • Last Post 06 February 2019
Tim Finke posted this 05 February 2019
Hi everyone,
we have a promise pegasus R6 with 6 drives à 1 TB so 6 TB in total. The info panel for the locgical drive is showing:
Capacity: 5 TB
Physical Capacity: 6 TB
Since we use the Raid as backup and it happened to be full we would like to use this 1 TB as well. Can anyone help?
Best,
Tim
PS. We are planning to replace all drives in the future …
Tim Finke posted this 06 February 2019
Hey Arun,
thanks for your help. We already ordered new 3 TB disks in order to replace the existing ones :).
I assume this also is done by creating a new array, right?
Thanks again and best regards,
Tim
arunkumar b posted this 06 February 2019
Hi Tim,
Pegasus have default RAID 5 configuration.RAID 5 is data striping with parity.It has one HDD fault tolerance(No data lost if single drive failure).The usable capacity in RAID 5 is Total HDD capacity subtract to one HDD capacity.i,e 6TB-1TB=5TB
If you still want to use total physical capacity 6TB ,you could backup the data from the drive ,delete and recreate the RAID choosing RAID 0 .But, it is not recommended as RAID 0 is disk striping without data redundancy(Data lost if single drive failure)
Please find the below KB article link  for how to create new RAID
https://kb.promise.com/search/?term=create+logical
Please let me know if you have any queries
Arun
