R4 FIRMWARE UPDATE ISSUE
  • 992 Views
  • Last Post 06 March 2017
Matt Dec posted this 06 March 2017
Hey all - having a problem updating my drive array.  If I go to the utility and check for updates, it says I need to update to 5.04.0000.57.  When I confirm and flash, it reverts to the 5.04.0000.36.  I have read others have had this problem and have manually downloaded the update but I cannot find it anywhere.
Does anyone knoe where the 5.04.0000.57 update can be located?
Or
Is there a more current update I should use from the downloads page?
I am still on Mavericks.
Joe Engledow posted this 06 March 2017
It's also known as Service Release 2.44 and it is in the Legacy Products section of Download Center.
http://www.promise.com/DownloadFile.aspx?DownloadFileUID=4122
If you are still having this problem please use the PTIFLASH command in the Promise Command Line Interface.
Within your Terminal app, type promiseutil.
At the CLIIB prompt type ptiflash -f, press the space bar, and then drag the downloaded file from downloads to the terminal window and release. Then press enter. It should go through the steps for flashing the firmware then prompt you to turn the Pegasus off and back on (power-cycle). Don't forget to eject the volume from Finder before powering the Pegasus off.
Thanks Guys - I tried the steps but I got htis error
cliib> ptiflash -f /Users/matthewdec/Desktop/R_SI_504000057.ndif
Image format is invalid.
Error (0x8055): invalid flash image
.NDIF is a partial download which is not complete. It should have the extension IMG when it is finished downloading.
That must be the problem then.  Each time I download it it finishes but never changes the extension to .img
