Promise Utility Pro issue with Pegasus2 firmware
  • 133 Views
  • Last Post 20 June 2023
Albert Julve posted this 18 June 2023
I have a Mac Studio with latest Promise Utility Pro installed v 23.4.1  and when I open it it always says that my Pegasus2 R6 has a firmware update, but it's already up to date! If I click on UPDATE NOW, it does nothing, says updating and takes forever without progessing the installation bar. I've checked the Pegasus2 support page and I already have the latest firmware on my Pegasus2.
Can someone please help me with this? It's very annoying. I don't know if it's a problem of the latest version of Promise Utility Pro. My computer has MacOs Ventura 13.4
R P posted this 20 June 2023
Hi Albert,
The issue of the Pegasus Pro Utility indicating that a firmware update is needed where the firmware is up to date has already been been reported.
But it is not recommended using the Pegasus Pro Utility if you have a Pegasus2. For a Pegasus 2 you should use an older version of the Promise (non-Pro) Utility, v4.06.0000.01 is suggested.
Albert Julve posted this 20 June 2023
Hi, thanks for your reply. The problem is that I also have a Pegasus3 R8 so should I just ignore the firmware update message? You think you'll be able to fix thw bug in a future software update of the Pro Utility?
thanks
Hi Albert,
The Promise Utility v4.06.0000.01 was released for the Pegasus32 and is backwards compatible with older Pegasus models.
Yes.
As mentioned previously, this has been reported as a bug already.
