Promise Utility Keep Asking to Update Firmware
  • 1.1K Views
  • Last Post 24 January 2017
Aldy Waani posted this 07 December 2016
Everytime i run Promise Utility it always asking me to update Firmware. I did update and power cycle the unit. but when i run Promise Utility it asking again.
Any ideas?
Here's the unit's info
Appreciate any thoughts.
Dinesh Kannusamy posted this 07 December 2016
Hi Aldy,
From the attached screenshot I could see the unit is still running on old firmware version 5.04.0000.36 and in case if there is any drive issues then the Promise utility may not allow to complete the update.
We can try to update the latest verison manually or without drives, Please contact Promise Tech support for further assistance on this.
http://www.promise.com/us/ContactUS/
Thanks..
Aldy Waani posted this 08 December 2016
Hi Aldy,
Thanks..
Hi Dinesh, thanks for your reply.  Acording to the Diagnostic, all 4 drives status is Healty. in good condition. And i didnt find any performance issue.
Is there any other way i can check the disk issues?
I did tried updating manually, same result. but I havent tried updating without Drives. Is it possible?
Raghuraman Kannan posted this 11 December 2016
Hi Aldy,
Please update the firmware using the below instructions and let us know if it worked.
- Unmount the volume
- Shutdown the pegasus
- Open Promise Utility and Unlock it.
- Click on promise utility ( near the Apple Icon)-> Check for updates.
- It would prompt for updating the firmware, update the firmware.
- After the update, please shutdown the unit and re-insert all the drives.
Thank you !
Andreas Jaunsen posted this 24 January 2017
I have the exact same problem and I tried the recipe suggested by Kannan. It does not work.
The correct help (manual installation from CLI) can be found here:
http://forum.promise.com/thread/pegasus-r4-firmware-update-and-compatibility-with-mac-el-capitan/
