Promise Pegasus not accessible
  • 1.6K Views
  • Last Post 04 May 2016
nick pomf posted this 20 April 2016
I was copying some files from my Pegasus when I got an alert saying "The disk had been ejected".  I can no longer see the Pegasus drive.  The Promise Utility won't start. I can't even switch it off, holding the power button down does nothing.  There are no errors, no red lights. I tried the command line but all I get is this:
cliib> array
DaId Alias     OpStatus      CfgCapacity FreeCapacity   MaxContiguousCapacity
No configured disk array in the subsystem
Peter Gunnell posted this 04 May 2016
Hi Nick,
Many thanks. The guys have tried to be very helpful thus far - online and by phone. Very quick to offer a replacement core unit which, after a false start (some problem clearly occurrred with a lost web form - it happens!) arrived today. Unfortunately it hasn't resolved the problem - still cannot 'see' it.
I'm back onto the guys and await their response (obviously very frustrating for me, but I still recommend them given their helpfulness so far). I'm just wondering if this is me/my set up (though I have no idea why) or if this problem is occuring to others, or has been a problem before?
I guess Im trying to reassure myself that there is light at the end of this particular tunnel!
Pete
R P posted this 26 April 2016
Hi Pete, Nick,
For cases like these you need to work with the TS team. You can open a support case at...
https://support.promise.com/
--Rich
Peter Gunnell posted this 22 April 2016
I cant "see" mine either. I was getting some disk ejection errors coming up with variable frequency. Had the problem of ejecting before but not as bad as this. I can see the drive in 'system information' but nowhere else. Utility and firmware is up to date, kept that way automatically.
I have contacted support who advised me to shut down, hal-remove drives, update again and send them file info from the utility. Problem is the utility cant see the drive so I cant access the full utility (at least, I presume thats what is going on). Tried via terminal w/o success.
Regards Pete
R P posted this 22 April 2016
Hi Nick,
I just responded to you about erasing your disk, did you get your issue resolved?
If not, for the above issus you should open a support case at https://support.promise.com
--Rich
