Kindly delete the existing Promise utility and the driver from /library/Extension folder, PromiseSTEX file.
Then use below link to download the driver and Promise utility:
For utility:
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6918
For driver:
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6963
Firstly, install the driver and check whether the volume got mounted or not.
If issue remains, kindly register the unit using the serial number by logging into support.promise.com and open a web support ticket with the service report of the unit attached so we could check further.
1) Open Promise Utility.
Below is the Promise KB link to attach report in CRM:
