Promise Pegasus 2 R8 driver not loading on my Mac Studio M1 Max
  • 245 Views
  • Last Post 09 January 2023
Natasha Alves posted this 05 January 2023
Hi guys,
My work Promise Pegasus 2 R8 driver is not installing on my M1 Max Mac Studio on Ventura 13.0.1. I have tried installing the driver R_MacDrv_V6_2_17-3 AND R_MacDrv_V6_2_16 with no luck.
I have followed the instructions perfectly, and it claims to be installed, however in System information, under the loaded column it still says "No", rather than "Yes".
The drive was loaded with footage on a Mac Mini in Monterey, whereas my Mac is on Ventura. Might this have anything to do with it?
Babatunde Akinkuolie posted this 09 January 2023
Kindly delete the existing Promise utility and the driver from /library/Extension folder, PromiseSTEX file.
Then use below link to download the driver and Promise utility:
For utility:
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6918
For driver:
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6963
Firstly, install the driver and check whether the volume got mounted or not.
If issue remains, kindly register the unit using the serial number by logging into support.promise.com and open a web support ticket with the service report of the unit attached so we could check further.
1) Open Promise Utility.
Below is the Promise KB link to attach report in CRM:
