Problems with first configuration E610F
  • 238 Views
  • Last Post 24 May 2021
Andrey Dvornikov posted this 21 May 2021
Good day!
I have a problem to configure E610f via serial cable connection.
When I start Microsoft HyperTerminal, I see:
*    SAS JBOD CONSOLE v1.7.0000.12    *
cli>
in this mode I can use only few commands:
enclosure
uptime
link
route
vpdr
cable
factorydefaults
help
and that's all.
I cannot login, I cannot assign ip address. What am I doing incorrect?
Please help!
R P posted this 24 May 2021
Hi Andrey,
This means that you have a serial cable wired the wrong way, probably from a different manufacturer. Many manufacturers make serial cables with the same connectors, but there is no standard configuration.
If you can't find the correct cable many vendors carry them, they cost from $12 to $16.
This google search for the part number should help.
https://www.google.com/search?&q=VRCABLERJ11
