Problem with Promise Pegasus 2R 8 / Finder doesnt shows Promise Pegasus
  • 602 Views
  • Last Post 06 June 2018
Donovan Aguilar posted this 05 June 2018
So, heres the thing.
Yesterday I was moving some files from a HDD to my Pegasus as a backup, but then I stopped the transfer on the Finder because i needed to leave.
Cancelling the transfer was taking too long, and i decided to shut down mi Mac Pro manually.
Today, Finder does not show Promise Pegasus anymore, even though I can see it on the system report.
I need to access my info so bad.
Ranjith kumar posted this 06 June 2018
Hi Donovan,
Please follow the below steps to see if you are not able to mount the unit.
-  Turn off the Pegasus unit, and your computer.
- Remove the thunderbolt cable from the Pegasus unit and the computer and wait for 30 seconds.
- Mark and remove all the drives from the unit.
- Reconnect the cable back to unit and to the computer.
- Turn on the Pegasus unit without the drives and turn on your computer.
- Please open Promise Utility and see if the utility is able to see the unit.
If you are able to access the unit without the drives then save the subsystem report without the drives
and then insert the drives one by one to its respective slots to see if the volume is mounted.
If  you still facing an issue,kindly create a web spport case at support.promise.com and attach the subsystem report in that case id
to help further.
