Pegasys2 R4 seems to go offline
  • 464 Views
  • Last Post 29 October 2019
Harlan Lax posted this 22 October 2019
Using a Pegasus2 R4 with the latest firmware conneced to a Mac mini running 10.10.5 server
If I power off and on the Promise unit I can accesss the riad array and use the promise utility but after a short time (1 minute) it disappears and I can't even run a subsystem report.
The unit is out of warranty.
Has anyone seen this behavior and how do I go about fixing it if I can't even run a report?
Wendy Wei posted this 25 October 2019
Hi Mr. Lax,
Please go to our CRM system at https://support.promise.com, and submit your request.
Raghuraman Kannan posted this 29 October 2019
Hi Harlan,
Please check the THunderbolt connections and make sure the cables are not damaged. You could try swapping the Thunderbolt slots on the Pegasus and change the cable ( if possible) to see if it works.
If not resolved, Please register your email address and your Product  @ https://support.promsie.com and open a Web Case for further asssitance. We will take it forward from there.
