Pegasus32 R8 no mount on MacStudio or MacMini M1
  • 744 Views
  • Last Post 27 December 2022
Chris Brown posted this 08 May 2022
pegasus32 R8  did mount on MMm1 prior to OS update.
R8 in Raid 6 config was working
New MacStudio and also updated MacMini m1 to Monterery
neither will mount
neither will install the utility
Gautham Sakthi posted this 12 May 2022
Hello Chris,
Kindly create a websupport case by going to support.promise.com. If you have not signed up then please sign up, register the unit to create a case so that we will be able to assist you further.
Below is the driver link for M1 MAC :
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6798
It has a PDF file please read it before installing the driver so that you can follow the instructions.
Utility for M1 MAC :
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6878
Chris Brown posted this 12 May 2022
ok.
THe latest drivers were installed the day before.
following this:
Pegasus32
R4, R6, R8
Product Manual
have installed the driver you linked, and enabled allow.. ; the Studio now mounts the P32R*, thanks.
Juan Neumann posted this 27 December 2022
Hello Chris,
Kindly create a websupport case by going to support.promise.com. If you have not signed up then please sign up, register the unit to create a case so that we will be able to assist you further. Your Texas Benefits
Thank you so much for the informative and interesting post I like your points which you have discussed over here, great job.
