pegasus32 R8 did mount on MMm1 prior to OS update.
R8 in Raid 6 config was working
New MacStudio and also updated MacMini m1 to Monterery
neither will mount
neither will install the utility
neither will mount
ok.
THe latest drivers were installed the day before.
following this:
Pegasus32
R4, R6, R8
Product Manual
have installed the driver you linked, and enabled allow.. ; the Studio now mounts the P32R*, thanks.
Hello Chris,
Kindly create a websupport case by going to support.promise.com. If you have not signed up then please sign up, register the unit to create a case so that we will be able to assist you further.
Below is the driver link for M1 MAC :
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6798
It has a PDF file please read it before installing the driver so that you can follow the instructions.
Utility for M1 MAC :
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6878
