R P
posted this
20 December 2022
- Last edited 20 December 2022
Hi Dinu,
I just checked 2 Pegasus R6 units in my lab. My Black Magic settings may be different from yours. These were run on an M1 MAC mini.
These results are from the Pegasus 2 R6 which was already attached through a TB2 > TB3 converter.
Most likely 830 MB/s is about the bandwidth limit of Thunderbolt 2.
These reaults are from a Pegasus32 R6 connected by Thunderbolt 3.
My write speeds are slower than yours but the read speed is about the same.
The thing about writes is that they are cached, that is the writes are saved to cache memory rather than being written straight to disk. Reads come straight from the disk. This means that often write speeds are faster than read speeds depending on how things are implimented and what kind of IO is being run. But read speeds being slower is not unexpected or a sign of a problem.
But with spinning disks (which you have) your results look good.
