Pegasus32 R4 DisplayPort Display not going into power saving mode
  • 51 Views
  • Last Post 13 March 2023
Leon Shaner posted this 13 March 2023
I have a brand new 16" MBP M2 Max 2023, which just replaced a 16" MBP Intel 2019.
I used Migration Assistant to move into the new MBP.
I connected my two Pegasus32 R4 the same way as I did on the old MBP, which is via two separate Thunderbolt cables, directly into Thunderbolt jacks on the MBP.
I have a large display in Picture-By-Picture mode presenting two separate DisplayPort conections, one to each Promise Array (e.g. each array carries one Thunderbolt -> DisplayPort connection).
With the new MBP, my external displays no longer sleep when the Mac is set to blank them, nor do the displays sleep when the MBP is actually asleep nor when the MPB is completely shut down.  I can still see the LED backlighting is on and my power meter shows that the display is drawing 80 watts.
Everything else is fine w.r.t. power management of the arrays, it's just that the display is not being told to go to sleep when called for.
One change that I made in conjunction with moving to the new MBP is that I first upgraded the FW on the two Pegasus32 R4's to the latest version.
So I can't be certain if the displays not power-saving is due to the change in MBP hardware or the change in Pegasus FW.  :-/
Any ideas?
P.S. I can see a Pegasus32 category with a test message, but when posting this message the I don't see it. Nearest is Pegasus 3.  Admin feel free to move my message.
More deets:
    System Power Settings:
      AC Power:
          System Sleep Timer (Minutes): 10
          Disk Sleep Timer (Minutes): 10
          Display Sleep Timer (Minutes): 10
          Sleep on Power Button: Yes
          Wake on LAN: Yes
          Current Power Source: Yes
          Hibernate Mode: 3
          HighPowerMode: 0
          LowPowerMode: 0
          PrioritizeNetworkReachabilityOverSleep: 0
      Battery Power:
          Display Sleep Timer (Minutes): 3
          Wake on LAN: No
          Hibernate Mode: 3
          HighPowerMode: 0
          LowPowerMode: 0
          Reduce Brightness: Yes
      UPS Power:
          Display Sleep Timer (Minutes): 2
          Wake on LAN: No
          Hibernate Mode: 3
Deets:
Alias: Pegasus32 R4 Backup
OperationalStatus: OK                  PowerOnTime: 9 minutes
LUNAffinity: N/A                       LunmappingMethod: WWN Based
CacheUsagePercentage: 0%               DirtyCachePercentage: 0%
Vendor: PROMISE                        Model: Pegasus32 R4
PartNo: F29C1R620000000                SerialNo: XA0099003024
HWRev: A2                              WWN: 2000-0001-5562-b95b
CmdProtocol: SCSI-3                    CBSN: MD3L19508200020
MemType: DDR3 SDRAM                    MemSize: 1GB
FlashType: Flash Memory                FlashSize: 8MB
NVRAMType: FRAM                        NVRAMSize: 128KB
BootLoaderVersion: 6.06.0000.45        BootLoaderBuildDate: Nov 15, 2022
FirmwareVersion: 6.06.0000.45          FirmwareBuildDate: Nov 15, 2022
SoftwareVersion: 6.06.0000.45          SoftwareBuildDate: Nov 15, 2022
BIOSVersion: 6.06.0000.45              BIOSBuildDate: Nov 15, 2022
SingleImageVersion: 6.06.0000.45       SingleImageBuildDate: Nov 15, 2022
CtrlCPLDVersion: 7.03                  Init String Model: Pegasus3 R4
DiskArrayPresent: 1                    OverallRAIDStatus: OK
LogDrvPresent: 1                       LogDrvOnline: 1
LogDrvOffline: 0                       LogDrvCritical: 0
PhyDrvPresent: 4                       PhyDrvOnline: 4
PhyDrvOffline: 0                       PhyDrvPFA: 0
GlobalSparePresent: 0                  DedicatedSparePresent: 0
RevertibleGlobalSparePresent: 0        RevertibleDedicatedSparePresent: 0
RevertibleGlobalSpareUsed: 0           RevertibleDedicatedSpareUsed: 0
WriteThroughMode: No                   MaxSectorSize: 4KB
PreferredCacheLineSize: 64 KB          CacheLineSize: 64 KB
Coercion: Enabled                      CoercionMethod: GBTruncate
SMART: Disabled                        SMARTPollingInterval: 600 minutes
MigrationStorage: DDF                  CacheFlushInterval: 3 second(s)
PollInterval: 15 second(s)             AdaptiveWBCache: Disabled
ForcedReadAhead: Enabled
PowerSavingLevel: 3                    SpindownType: All drives
IdleTimeToParkRwHeads: Never           IdleTimeToLowerRotationSpeed: Never
IdleTimeToSpinDown: 1 hour
SGPIOBackPlane: Default/Generic (0)    SASReadyLED: Off
SpinUpDelay: 0 millisecond             PowerManagement: Enable
SecurityAdminPassword: N/A
PciFuncAddr: N/A                       PciLinkSpeed: N/A
PciLinkWidth: N/A
