Pegasus3 R8 will not work on system above Sequoia 15.4.1 mac?
  • 249 Views
  • Last Post 18 November 2025
Morten Madsen posted this 18 November 2025
Hi! I'm on a Mac OSX M1 Running Sequoia 15.4.1, i get this messeage that if i update the mac my  promise no longer will be supported? And i just tried to update and yes no longer can i mount my Pegasus3 R8!
So i had to downgrade to Sequoia 15.4.1 and that did the trick it works again!
BUT what to do when i eventaually do want to upgrade in the future?
R P posted this 18 November 2025
Hi Morten,
The Lab's M1 Mac Mini is running Tahoe and the Pegasus works fine, no issues.
My best guess is that you installed the KEXT driver when the M1 Macs first came out as the DEXT driver was not yet available. Apple has been announcing that third party KEXT drivers are deprecated and will stop working at some point.
The solution is to install the DEXT driver.
