Pegasus3 R8 not powering on. Pushed power button and it flashed red for a second then went black.
  • 182 Views
  • Last Post 09 January 2023
Cliff Van Koppenhagen posted this 04 January 2023
I assume this means the power supply went bad?
Can I pay Promise to replace the power supply, if that's what it s?
Babatunde Akinkuolie posted this 09 January 2023
Try with a different thunderbolt cable and check if the unit is getting mounted
Mark the drives power off the unit and remove the drives power on the empty unit and check if the unit is detected
You can also check on Promise Utility if the unit is found.
  • Herbert Carter
