Pegasus2 R8 Replace Drive with different model
  • 280 Views
  • Last Post 21 August 2019
Paul Rumens posted this 01 August 2019
Currently my R8 is filled with Toshiba DT01ACA300 Drives
I know that in the past, you should always replace like for like, but buying therse old drives is getting hard.
Can I replace it wil any 3TB Drive
Ranjith kumar posted this 16 August 2019
Hi Paul,
Yes, you can replace with any 3TB drives.
Also you can verify below link to download the compatiblity list for Pegasus2 series:
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6110
Thank you,
Ranjith
Paul Rumens posted this 21 August 2019
Hi Ranjith
Thats a very short list of drives, for 3TB drives, only the ST3000DM001 and DT01ACA300 are supported.
To confirm, any 3TB drive should work, but only the ST3000DM001 and DT01ACA300 have been verified by Priomise. Is that correct?
